<< Click to Display Table of Contents >> User data |
When starting PVsyst for the first time, a user data structure is created or imported. It is called a workspace.
The default location is: C:\Users\<username>\PVsyst7.0_Data
It contains every data created through PVsyst by the user: projects, PV components,...
The workspace can be easily managed:
•create a new one,
•import an existing one,
•export the current one (backup),
•switch to another one.
PV components you have defined can also be managed:
•import external elements,
•export to an external directory.
