<< Click to Display Table of Contents >> Export projects and components |
The tool for exporting projects and components could be started from menu called "File -> Export components" on the main screen.
The first thing to do is to specify where to put data to export:
•You could select an empty directory: the tool will automatically create the required directories.
•You could select a PVsyst data structure (PVsyst7.0_Data\ or Data\): the tool will export files to the correct directories.
Then wait for the tool to analyze the data: a representation of the current workspace is on the left panel. The export directory is displayed on the right panel.
On the left panel every files could have 4 states:
•FileName.Ext written in normal font: the file is not exported for the moment.
•FileName.Ext written on grey background: the file is already exported in current workspace.
•FileName.Ext* followed by a star: the file is already exported in current workspace but has different content.
•FileName.Ext written in italic font: a same component is already defined in PVsyst's built-in database.
•On the left panel, open the Projects section: projects to export are displayed followed by their simulation variants. You could export the full projects (including all variants) or just one or more variants.
•Click on the project to select it. Tip: use Ctrl+Click to select more than one element.
•Then click on the >Export> button. Depending on what you would like to export, it could ask you:
oif you would like to export referenced files: referenced files for a project are defined here.
▪Yes: it will copy the full projects including all referenced files.
▪No: it will only copy the project itself.
oif you would like to overwrite files: if some files already exist in the target directory you could replace them.
▪Yes: replace the file in target directory by the one to export.
▪No: keep the current file in target directory.
•Wait for the end of the exportation: elements you exported (and maybe referenced files) are displayed on right panel (the target directory).
•On the left panel, open the ComposPV section, then open Batteries or Gensets, ... Tip: you could also export any files from the left panel (meteo or shadings for example).
•Click on the component to select it. Tip: use Ctrl+Click to select more than one element.
•Then click on the >Export> button. Depending on what you would like to export, it could ask you if you would like to overwrite files: if some files already exist in the target directory you could replace them.
•Wait for the end of the exportation: element you exported are displayed on right panel (the target directory).
You could compress as a zip file the whole structure displayed in the right panel: to do so, just click on Zip export folder... button and specify an output zip file name.
Wait until the end of compression process: a pop-up shows where the zip file containing the export folder is stored.
