A project (design project) involves several files, which should be placed in a well-defined directory structure. Files are described in more depth here.
\Projects\
ProjectName.PRJ | The project itself |
ProjectName.VCi | Simulation variants |
ProjectName.Cmi | Comparison variants |
\Meteo\
MeteoFile.MET | The hourly meteo files associated to the projects |
\DataMeas\
Datameas.DAM | Eventually if comparisons with measured data |
\ComposPV\ | Components, only those modified or added by the user: |
\Regulators\ | Regulator.RLT |
\RegulPmp\ | PumpRegulator.RLP |
Note: Preliminary design projects are made of one file only, with extension .PSG (grid) or .PSS (stand-alone).
Projects and components can be imported from external files or exported to external files.
