<< Click to Display Table of Contents >> Import projects from a zip file |
The tool for importing projects from a Zip file is located in the menu called "File -> Import projects" on the main screen. It imports complete projects including all related files.
First of all, open a zip file containing exported projects (see Export project). It shows a list of the contained projects with the name and the number of simulation variants.
Then click on the Import button. It will ask you to overwrite files if some already exist.
