<< Click to Display Table of Contents >> Export projects to zip file |
The tool for exporting projects to a Zip file is located in the menu called "File -> Export projects" on the main screen.
It shows a list of all your projects, with the name and the number of simulation variants.
First of all, select which projects you would like to export. Use Ctrl+Click to select more than one project.
Then, click on the Export button and choose a path and name for the zip file which will contain the selected projects.
