<< Click to Display Table of Contents >> Table of low-light measured points in Excel |
Defining the low-light data within the PVsyst dialog may be tedious.
PVsyst allows to define a table in EXCEL, and import it into the low-light tool by copy/paste.
The table should have the following characteristics:
The top left cell should contain the text "Low-light data".
The second line contains the column titles, which should be the same texts as shown here, but in any order.
NB: Only GRef, TRef and Pmp are mandatory. If Voc is present it will allow the linearization.
Blank lines are ignored.
You can define a table of the full 23 values of the IEC 81853 norm.
