<< Click to Display Table of Contents >> Files: Questions and Answers |
Often, some files or directories are not visible in the Windows file explorer.
For visualizing all existing files, you should modify the parameters of the Windows file explorer:
- Under Windows 7 and Vista: click "Organize" top left of the menu, choose "Options of the files and research".
- Under Windows XP, this tool is in the menu "Tools" / "Directories options" on the right.
In this windows tool, please choose "Display" / "Advanced parameters", and in the box "Hidden files and directories", check "Show the hidden files, directories and disks".
A bad file can disturb the normal execution of the program and produce unrecoverable errors.
Invalidating it puts a "$" as first file name's character.
You will always be able to rename it when necessary.
