<< Click to Display Table of Contents >> Voltage Lithium-ion model |
(go directly to the help section of the form, "Batteries - Detailed model parameters (lithium-ion)")
With the lithium-ion model, the internal resistance depends on temperature and the Open Circuit Voltage depends on SOC only.
This differs from the lead-acid model.
Lithium-ion voltage model |
Charge |
Discharge |
With the lithium-ion model, the capacity correction according to the discharge rate is handled through the peukert coefficient
The capacity correction according to the temperature is handled similarly as the lead-acid model, with experimental correction coefficients which are fit to catch the behaviour as best as possible.
