User's needs: monthly values definition
When entering this monthly definition tool, please first choose the working units.
At the first entry all values are null. You can use the operator facility to modify all values at a time:
First choose the operator, which can be:
  • Fix identical values for each month,
  • Add a given value to each month,
  • Multiply all values by a given value,
  • Renormalise all values to obtain a given yearly sum or average.
Then define the Operator value, and click "Work out".
You can also drag each monthly value on the graph, or define a given value by editor.
NB: If you are in "daily profile" mode, the Next button will open the similar Daily values dialog.
