Batch mode - Parametric studies
Principle
The batch mode in PVsyst allows you to run several simulations in one go, while varying some simulation parameters. The results are gathered in a spreadsheet on which you can perform easily a parametric study.
To perform a batch run, you start with a window where you can:
  • Choose the parameters to be varied
  • Choose the variables to be output (in yearly values) on the spreadsheet file
This will create an CSV document that you should open in a spreadsheet program like EXCEL or LibreOffice.
In the spreadsheet - before executing the simulations:
  • Open the CSV document and add one line for each simulation that should be run, specifying the parameters to be applied.
Run the simulations. This will create a result file in CSV format, that can again be opened in the spreadsheet software.
  • Open the Results file: you have a table of the parameters and the requested yearly results for each run.
Detailed procedure
Just before the simulation, button Batch simulations.
1. Batch CSV files page
  • Input file: this indicates the CSV file to be defined for the parameters (fixed name, with BatchParams tag, always located in \UserBatch )
  • Output file: this indicates the output CSV file ( (fixed name, with BatchResults tag).
2. Parameters specifications page
You have to choose the parameters you want to modify during your multiple executions:
Weather data and Save Mode
  • You may specify several weather data files. This can be used, for instance, to run all years from a time-serie. In this mode PVsyst first checks if the specified weather data files exist in the database and if they are valid. PVsyst will then consider the climatic distance between the geographical site and the weather data files, and, if above the limit *, the weather data site coordinates (lat, long, alt) will be transfered into the geographical site coordinates.
  • You may specify several locations. This can be used, for instance, to challenge several geographical options for your project. In this mode PVsyst first checks if the specified sites exist in the database. If so, 2 possibilities :
    • at least one weather data file (.MET) is available in the surroundings *. The nearest weather data file is then selected.
    • no weather data file available in the defined area. PVsyst will generate a synthetically weather data file using the Meteonorm Dll.
  • Choose if you want to start from VCi base files that differs from the current selection.
  • Choose if you want to save the simulation version files (*.VCi).
  • Consider the possibility to create hourly output files
(*) Default setting is 15km. This limit may be changed, see the Hidden parameter "project site - Weather data distance for auto synthetic proposal" - category Miscellaneaous : weather data, simulation,...)
Plane orientation
  • Modify tilt and azimuth for fixed tilt orientation (presently limited to a single orientation) plus shed characteristics (pitch, electrical effect) if unlimited sheds defined.
3D shadings parameters
  • Sheds: define pitch, collector width,
  • Tracking: pitch between trackers or rows, backtracking, stroke angles, etc
System parameters
  • PV module type, number in series and number of strings, module quality loss.
  • Inverter type, number of devices.
If you think other parameters are worthwhile to be varied in this tool, don't hesitate to ask us.
3. Results variables specifications page
You can choose here any simulation variable, to be mentioned in the results of the CSV file as yearly results.
Before the simulation
When closing this dialog, you are invited to
  • open the file MyProject_BatchParams_i.CSV in \UserData with EXCEL
  • Define the table of parameters (one line per execution, fill the columns of parameters to be varied)
  • You are advised to carefully define comments as remainders of the varied parameters
  • Be sure to close this file before performing the simulation.
After the simulation
You will find the results in the file "MyProject_BatchResults_i.CSV", to be analyzed in EXCEL.
Advice: you can delete the files "MyProject_BatchParams_i.CSV" and "MyProject_BatchResults_i.CSV" after use and gathering them in your working EXCEL XLS documents.
A new file "Myproject_BatchParams_i.CSV" is created at each opening of the batch tool: you can never reuse a "MyProject_Params_i.CSV" file, except by copy/paste its parameters (but be careful with the matching of the columns with titles).
