Automatic identification
When defining PV fields in a shading scene through import or when filling zones, PVsyst will always try to identify their orientations automatically, grouping all similar fields into the same orientations.
Here is a list of situations and how PVsyst will behave :
3D import:
Fields are grouped by their nominal tilts and azimuths with a tolerance of 0.1° on each, and their baseslope will not affect the way they are grouped.
Zones of tables:
Fields are grouped within the same zone, and with other zones if they share the same tilt and azimuth definitions.
For all scenarios, PVsyst then computes an average tilt, azimuth and baseslope for each orientation from its fields.
This is the way orientations are defined automatically since PVsyst 8.0.0.
