PV Collada file format
The PV Collada file format has been created by the PVsyst team in collaboration with the PVCase team in order to provide an open-source exchange format to describe 3D PV scenes.
PV Collada files can be imported into PVsyst since version 7.0.
Format description
PV Collada files use the .PVC extension.
The format is based on the Collada 1.5 format (full specifications available on the Khronos group website).
Extension of the \<mesh> tags
The <mesh>
tags can contain an additional child element from the following ones :
frame_parameters
tracker_parameters
It must contain only one of these and not the two simultaneously.
Adding one of these tags to the mesh will define it as a PV mesh and each of its faces will be converted to such in PVsyst after the import.
<frame_parameters>
This element describes a fixed-tilt table, it must contain the following child elements :
module_width
: INTEGER type, millimeters, describes the width of a module contained in the tablemodule_height
: INTEGER type, millimeters, describes the height of a module contained in the tablemodule_x_spacing
: INTEGER type, millimeters, describes the horizontal spacing between modules contained in the tablemodule_y_spacing
: INTEGER type, millimeters, describes the vertical spacing between modules contained in the tablemodule_manufacturer
: STRING type, describes the name of the module manufacturermodule_name
<tracker_parameters>
This element describes a tracker, it must contain the following child elements :
module_width
: STRING type, describes the name of the module manufacturertracker_type
: STRING type enumeration ("single_axis_trackers", "dual_axis_trackers"), describes the kind of trackersaxis_vertices
: this element must contain two child elements of typewith a length of 3, describing the global coordinates of the two axis points min_phi
: INTEGER type (between -90 and 90), degrees, describes the minimum E-W tracking rotation anglemax_phi
: INTEGER type (between -90 and 90), degrees, describes the maximum E-W tracking rotation anglemin_theta
: INTEGER type (between -90 and 90), degrees, describes the minimum N-S tracking rotation anglemax_theta
: INTEGER type (between -90 and 90), degrees, describes the maximum N-S tracking rotation angle
Sample PVC files can be found in the DataRO/PVsyst8.0_Data/Userdata
subfolder of the PVsyst installation folder.
