Object selection
A few tools are available in order to select objects in the 3D scene.
Basic object selection
Select The basic selection is made by left-clicking on one edge of the object. You can select more objects by pressing Ctrl and left-clicking on the other objects you want to add to selection.
Clicking on an empty area will reset selection.
Rectangle selection
RectangleSelection This tool allows you to draw a rectangle on the scene and select/deselect objects which are either touched by the rectangle or completely inside it.
When you click on this button, the following menu pops up and allows you to choose what you wish to do.
RectangleSelectionMenu
Clicking on the button one more time will disable the drawing but keep your current selection.
Lasso selection
LassoSelection This tool allows you to draw a free shape on the scene and select/deselect objects which are either touched by the drawing or completely inside it.
Objects list
SceneObjects
You can select objects directly in the list and use Ctrl or Shift to select multiple objects.
