Conversion of single tables to arrays of tables
You may want to transform single PV tables to arrays of tables at some point in PVsyst. This section explains how to do that.
First select the single tables that you want to convert in the 3D scene:
TransformToArraysMainView
Then click on the menu called "Transform -> Transform selected PV tables to arrays of tables":
TransformToArraysMenu
The PV tables have now been transformed to arrays of tables (one array for each table that was selected):
TransformToArraysResultView
