Simulation variables: Stand alone system
The following variables are calculated during the simulation process, and available as results:
Weather data and irradiation variables: see previous page.
PV array behaviour
EArrMPP
Array virtual energy at MPP (after wiring, module quality and mismatch losses),
Virtual calculation independent of the system running and voltage operation
EArUfix Array virtual energy at fixed voltage
Voltage as calculated by the balance loop (real battery voltage),
or Battery reference voltage when PV-array disconnected.
EUnused Unused energy (full battery) loss (EArUFix when Charging OFF)
MPPLoss Loss with respect to the MPP operation (when charging ON)
Earray Effective energy at the output of the array (when charging ON)
     IArray Array Current (accumulated in Ah)
     UArray Array Voltage (average when Charging ON)
     ArrayON State / Duration of the PV production of the array
If converter present: converter losses
CL_Oper Converter loss during operation (efficiency curve)
CL_Pmin Converter Loss due to power threshold'
CL_Pmax Converter Loss due to power overcharging
CL_Vmin Converter Loss due to low voltage MPP window
CL_Vmax Converter Loss due to upper voltage MPP window
CnvLoss Global converter losses
OutConv Energy at converter output
Battery operation: storage, losses and ageing
EBatCh
Battery Charging Energy
     U Batt Average battery voltage, any conditions,
     UBatCh Battery Voltage during charging operation
     IBatCh Battery Charging Current (all currents accumulated [Ah])
     ChargON Charging duration
EBatDis Battery Discharging Energy
     UbatDis Battery Voltage during discharge operation
     IBatDis Battery Discharging Current (all currents accumulated [Ah])
     DischON Discharging duration
ESOCBal Stored energy balance (according to SOCEnd - SOCBeg)
     SOCmean Average State of Charge during the period
     SOC Beg State of Charge at beginning of time interval'
     SOC End State of Charge at end of time interval'
NB: The SOC evolution calculation is referred to the actual capacity of the battery, which varies with the discharge current and the temperature. Therefore it is not quite well determined, and not reversible (it may be different when charging and discharging).
EBatLss Battery global energy loss   (EBatCh - EBatDis - ESOCBal)
     IBEffL Battery charge/discharge current loss (coulombic efficiency [Ah])
     IBGass Gassing Current loss (electrolyte dissociation [Ah])
     IBSelf Battery Self-discharge Current (depends on temperature [Ah])
EBattEff Battery energy efficiency (IBEffL * U Batt)
EBGass Gassing Current energy loss (IBGass * U Batt)
EBSelf Battery Self-discharge Energy (IBSelf * U Batt)
NB: The sum of the detailed battery losses contributions appearing on the loss diagram should in principle match this Battery Global Energy Loss calculated above, i.e:
EBattLss = EBattEff + EBSelf + EBGass
But during the simulation, all these contributions are determined from the Currents balance of the system (PV array - Battery - Load), multiplied by the Battery Voltage, which is varying with currents, charge/discharge state, state of charge, temperature, etc. Moreover, the stored energy ESOCBal is based on the capacity, which is varying according the conditions (current and temperature). The resulting energies are therefore defined with some uncertainties. Therefore the overall energy balance on the battery cannot be quite rigorous.
     WeCycle Wearing due to cycling
     WeState Wearing state (cycling and age)
     MGass Dissociated Electrolyte Mass per cell
System operating conditions
E_BkUp Back-up Generator Energy (UBatt * I BkUp)
     I_BkUp Back-up Generator Current' (accumulated in Ah)
     BkUp_ON Back-up Generator running duration
     FuelBU Fuel consumption of Back-up Generator
Energy use
E_Avail Available Solar Energy Energy at the output of the array when producing - converter loss + Unused energy
E Avail = E Array - CnvLoss + E Unused
E_Load Energy need of the user (Load) Defined as Input data
E_User Energy supplied to the user Including back-up energy
     SolFrac Solar fraction (EUser - EBkUp) / ELoad
When no back-up generator defined
E_Miss Missing energy Eload - Euser
     SolFrac Solar fraction EUser / ELoad
     T_LOL Duration of "Loss of Load" Duration user not supplied
     Pr_LOL Probability of "Loss of Load" Idem as percentage of time
Efficiencies
EffArrR Array Efficiency EArray / rough area
EffArrC Array Efficiency EArray / cells area (=0 when cells area not defined)
EffSysR System efficiency E User / rough area
EffSysC System efficiency E User / cells area (=0 when cells area not defined)
EffBatI Battery current charge/discharge efficiency
EffBatE Battery energy charge/discharge efficiency
Normalised performance index
(Read more about Normalised performance index)
Yr Reference Incident Energy in collector plane = GlobInc [kWh/m²/day]
Yu Normalized Potential PV Production (battery never full) [kWh/kWp/day]
Ya Normalized Array Production = EArray [kWh/kWp/day]
Yf Normalized System Production = EAvail [kWh/kWp/day]
     PR Performance ratio = Yf / Yr.
Lu Normalized Unused energy = Yr - Yu
Lc Normalized Array Losses = Yu - Ya
Ls Normalized System Losses = Ya - Yf
     Lur Unused (full battery) Loss / Inc. Energy Ratio = Lu / Yr
     Lcr Array Loss / Incident Energy Ratio = Lc / Yr
     Lsr System Loss / Incident Energy Ratio = Ls / Yr
