Lagging and Leading
In an AC circuit, the current is ideally in phase with the voltage. But inductive or capacitive devices will produce a phase shift named phi ([-90° ... +90°) , described by "cos(phi)" or "Power Factor".
Many confusions may arise with the sign of this Phase shift. For a consumer device, we have 2 situations:
Lagging
  • Phi > 0
  • The current lags (follows) the voltage
  • This is produced by inductive devices (motors, transformers, etc)
  • This produces what is named "Lagging reactive power", expressed in [kVAr]
  • We can say that the plant produces Reactive energy.
Leading
  • Phi < 0
  • The current is ahead of the voltage
  • This is produced by capacitive devices,
  • This produces what is named "Leading reactive power", expressed in [kVAr]
  • We can say that the plant consumes Reactive energy.
Inverter output
Now the output circuits of the inverters have the possibility of electronically creating a Phase shift (consuming/generating reactive power) at "no energy cost", i.e. without consuming any additional Active Power. This means that the inverter produces a sinusoïdal current which is not in phase with the grid voltage.
Therefore the Grid managers may require from the PV plants to "consume" Reactive power, for compensating the Lagging Reactive power produced by the numerous motors on the grid.
In this case on the loss diagram, the denomination of the reactive energy is labelled "Reactive energy absorbed from the grid" when the required phi is negative (Leading).
