Pump model from FR as f(Pp) for fixed Heads
Grids of FlowRate (Power) curves for different Heads is the usual way of specifying the solar centrifugal pumps. These allow to get a very good determination of the Hydraulic/Power behaviour, but don't hold any information about the Voltage/Current characteristics.
Such data are suited only when the pump is coupled to the PV system through a power converter.
If needed, the basic function Ip (Up, Head) requires additional informations. These could be provided either by a set of Ip/Vp points for at least two head values (on which we can adjust curves), or by several parameters: Nominal voltage and Current at a given reference Head, ΔV/ΔI at fixed Head (i.e. dynamic resistance) and ΔI/ΔH at fixed voltage.
When specifying such parameters instead of curves, we assume linear behaviours, which will of course penalise the accuracy of the Ip(Up) characteristics.
