Weather Data Note 1: Monthly & Hourly Weather data files (.SIT/.MET)
PVsyst distinguishes two kinds of weather data:
Monthly weather data
*.SIT files, which are associated with every geographic site. Monthly data are used to build the hourly data.
Monthly weather data files contain :
- the site name, the country, the world region
- the geographical coordinates: latitude, longitude, altitude and Timezone.
- the monthly Global Horizontal Irradiation (GHI or GlobHor)
- the monthly averages of the ambient temperature
The files may also include optional data :
- the monthly Diffuse Horizontal Irradiation (DiffHor)
- the monthly average of Wind Velocity.
They can be defined :
- from the Geographical sites section using PVsyst routines
- from the Import weather data section using external sources
You are advised to carefully define the source of the data. Read also our note on horizon in weather data files.
*.SIT files are stored in the \Data\Sites\
directory.
Hourly weather data
*.MET files, which are used by the simulations.
Hourly weather data contains the hourly values of :
- Global Horizontal Irradiation (GlobHor or GHI) ,
- Diffuse Horizontal Irradiation (DiffHor),
- Ambient temperatures,
- Wind Velocity if available
The data are recorded for whole days (0H .. 23H). Step labels are referred to the beginning of the interval (i.e. the 12 h label corresponds to the 12-13 h interval). A complete file for one year occupies about 70 kB (53 kB without wind-velocity). When importing your own measurements, the weather data file can be restricted to limited periods, and even have full-days holes. In this case the date is included in each record on the file.
Hourly weather data can be obtained:
- from the Synthetic hourly data generation section
- from the Import ASCII weather data file section.
The characteristics and contents of hourly weather data files (*.MET files) can be visualized and analyzed thanks to the weather data tables and graphs tool.
The hourly weather data files (*.MET files) are stored in the \Data\Meteo directory.
