Pump data: detailed parameter
These are a complementary set of parameters.
Electric side
  • Motor type: reminds the choice of the preceding sheet
  • MPPT ou DC Converter (if any): asks for the model name (only informative, this doesn' refer to a device in the database).
  • Nominal Voltage: reminder of the preceding sheet. With DC converter: input voltage. In other cases: the most relevant operating voltage, often mentioned by the data sheets, even when the Voltage characteristics is not given. |
Other variables depend on the configuration:
  • Min/Max MPPT Voltage: the voltage windows for MPPT converter
  • Abs. Max Voltage, Abs. Max Current, Abs. Max Power: absolute maximum ratings at the input of the device (pump or converter), which should never be exceeded during the simulation. Corresponding protections should be specified in the Control Unit (either in the simulation, and in the reality !!!).
  • Maximum- and Euro-efficiencies, from which an efficiency profile will be constructed.
Hydraulic side
Choice of the Data Set available in the data sheets.
This will determine the model-type used by PVsyst for simulating the pump behaviour, and makes available the corresponding sheet(s) for input of the data.
