PV module in tabular form
The user has the opportunity of exchanging all the parameter Module with an EXCEL file, in tabular form (one line per module).
The Microsoft EXCEL document Components.xls
, located in your datastructure \PVsyst7.0_Data\UserData\, has been specially formatted for a good interpretation of the parameters (Required, Optional, Defined by PVsyst, etc.)
When editing the PV module dialog, the button Export to Table will store the data of the module in the clipboard, which you can "Paste" in EXCEL.
Inversely, if you "Copy" a valid line in the EXCEL sheet, a button Paste from Table will appear in the PV module dialog, which allows for importing the data in the PVsyst program (and file).
You can also export a set of chosen modules from the Module List in the "Tools" section on the software.
When importing new modules without Rshunt and/or Rserie parameters, these will be set to default values by the software, in order to offer a valid model immediately usable.
NB: The same feature is available for Inverters.
