Grid inverters - Main interface
Grid inverters parameter are defined through a 6-sheet dialog:
Sheet | Description |
Main Parameters | the identifiers and the fundamental properties of a specific inverter type, |
Efficiency curve | defines the detailed operating efficiency behavior, |
Additional Parameters properties and specificities of the inverter, | |
Output parameters | Power factor and Pnom as function of temperature |
Size and others | physical sizes and weight, as well as comments about technology, |
Commercial data |
The model used by the simulation is fully described in :
