<< Click to Display Table of Contents >> Regulator voltage switch |
Some commercial regulators offer a switchable battery voltage (usually 12/24V). The right switch position is not a characteristic of the regulator component, and will be chosen by the program according to the battery pack, before the simulation process.
Checks on voltage compatibility - as well as input and output maximum allowed currents - are performed before the simulation and will produce a warning when not matching.
