<< Click to Display Table of Contents >> PV components commercial data |
The commercial data - especially the retailers and prices – of the PV-components cannot of course be defined in the database, as they can vary from country to country. They are only meant to serve as a memo for the engineer.
Nevertheless, you have the possibility of defining the price of the components you are using, and to store the date when it was fixed.
These component prices may be fed directly in the economic evaluation of the "project design" part or globally in the price list from component database.
When using the "economic evaluation" tool, you can link the component price defined in your database. You also have a shortcut for defining or modifying the component price directly in the database.
During this process, the currency in the database may be different of the actual working currency of the economic evaluation tool.
To define prices for a component, you have to select a reseller of the component. You can define different prices for different sellers and quantities.
