<< Click to Display Table of Contents >> Orientation optimization |
This is a tool aiming to show the best suited orientation for a PV system, or what you loose when not optimally oriented.
The Transposition Factor is the ratio of the incident irradiation on the plane, to the horizontal irradiation. I.e. what you gain (or loose) when tilting the collector plane.
There are 2 tools in PVsyst for doing this:
Detailed optimizing tool
In "Tools" > "Transposition factor", you have a complete and accurate calculation using full Hourly meteo data over one year.
This computes 475 annual FT calculations table for a grid of tilts and azimuth plane orientations. Then, the tool shows the optimal orientation, and curves of "iso-transposition" orientations for different transposition factors.
Each curve is also labeled with the amount you loose with respect to the optimal orientation.
Now please observe that the optimization of the orientation depends on the planned use for the PV energy.
- | For grid-connected systems, the energy is usually sold at a constant price all over the year. The relevant optimum is then to maximize the yearly energy. |
- | For stand-alone systems, the relevant solar yield for sizing the system may be, for example, the winter months for a house or industrial system; or some specific months for leisure appliances. |
- | For pumping systems, it may depend on the final use of the water pumped: household (all over the year) or irrigation (some specific seasons or months). |
Therefore this tool gives the possibility of choosing the optimizing period: Year, Winter, Summer, or chosen months.
Moreover, the optimization may depend on specific far-shading conditions (mountains): you can define a horizon line, and this will usually result in an azimuth displacement.
Now you can observe that the summer optimization has usually a flat optimum: you have high freedom for adjusting the plane orientation without loosing much, especially when the tilt is low. This means also that the optimum can be displaced towards east or west, with very low differences in absolute values. With hourly measured data, the optimal azimuth may be displaced because specific meteo behaviors like frequent fogs in the morning, storms in the evening, etc.
As a contrary, specific optimizations, for example in winter, are much more marked (sharp distributions around maximum): the iso-transposition curves are closer to each other, you have less freedom for a good orientation,.
Quick optimizing tool in the "Orientation" part
When choosing the (fixed) plane orientation, an information panel indicates the corresponding Transposition Factor, the difference (loss) with respect to the optimum orientation, and the available irradiation on this tilted plane.
Clicking the "Show optimization" button, you can see a graph of the Transposition Factor as a function of the plane tilt and azimuth. These graphs also indicate your actual choice by a violet dot on the curves, showing at once where you are positioned with respect to the optimum.
NB: | This tool makes use of the Monthly Meteo calculations, which perform quick transpositions from the Monthly Meteo values. The whole calculation for the curves is performed for several situations, in both directions from the point you have chosen (tilts at fixed azimuth, and azimuths at fixed tilt). This tool therefore only gives a quick estimation, which may be different from the real values in the detailed simulation. |
