<< Click to Display Table of Contents >> Object selection |
A few tools are available in order to select objects in the 3D scene.
Basic object selection
The basic selection is made by left-clicking on one edge of the object. You can select more objects by pressing [Ctrl] and left-clicking on the other objects you want to add to selection.
Clicking on an empty area will reset selection.
Rectangle selection
This tool allows you to draw a rectangle on the scene and select/deselect objects which are either touched by the rectangle or completely inside it.
When you click on this button, the following menu pops up and allows you to choose what you wish to do.
Clicking on the button one more time will disable the drawing but keep your current selection.
Lasso selection
This tool allows you to draw a free shape on the scene and select/deselect objects which are either touched by the drawing or completely inside it.
Objects list
You can select objects directly in the list and use [Ctrl] or [Shift] to select multiple objects.
