Sub-field area in Module Layout
Navigation:  »No topics above this level«
Return to chapter overview
A "sub-field area" is a (geometrical) surface element for receiving the PV modules. It is usually a "Table".
This should not be confused with the sub-arrays that you have defined in the "System" definitions, which concerns the electrical arrangements in strings ("homogeneous" for a set of inverter inputs).
You can construct here sub-field areas of any shape, for receiving the modules of your system. You can define as many sub-field areas as necessary, by using the button "Add", independently of your electrical sub-arrays. For example in sheds arrangements, you will define a sub-field area for each shed.
For complex systems, you are advised to give significant names (can be typed in the ComboBox) to each sub-field. These names will namely appear in the wiring schema output of this tool, assigning each module to an electrical string.
