Importing WRDC data
Importing WRDC data
You can access the WRDC data, using this NASA site, and easily import them in PVsyst:
-  Go to the NASA site     http://eosweb.larc.nasa.gov/sse
- Click    "Ground Sites",  and then  "Monthly Plots".
- You will be prompted for registration with your e-mail address and a password (free).
- Here you have 2 possibilities:
- Either you choose geographic coordinates, and the nearest site will be selected,
- Or you select a country, and then a site in the country.
- Select the   Monthly Averages item  (other ones are daily values).
The required data will appear, along with the geographic coordinates.
- Select the data from the  Country name to the bottom of the table, and copy  (Ctl-C) into the clipboard.
Come back to PVsyst,   "Tools" / "Import Meteo Data" / "WRDC",  press "Import" and follow the instructions in red.
As they are not included in the WRDC data, you will be prompted to define the monthly temperatures from another source.
See also this page for more details on the WRDC project.
