<< Click to Display Table of Contents >> Data elimination in Tables |
You can mark (eliminate) break-down data in the tables by clicking on the desired line:
- With the left button : elimination,
- With the right button : to restore data.
The eliminations performed in daily values will be thrown back to all hourly concerned values.
You can also perform eliminations directly on comparisons graphs. These eliminations are of the same kind and will appear here if saved with the data file (.DAM file).
NB. If you modify the data eliminations, the program will ask you for saving theses modifications on the data file.
