<< Click to Display Table of Contents >> Amorphous modules: Spectral correction |
The reference irradiance used for the simulation (the meteo values) includes the whole spectrum from 305 nm (UV) to 2800 nm (IR). It is usually measured with pyranometers, which have a practical flat response over this whole interval.
But each PV technology is characterized by a spectral sensitivity curve. When the SI-crystalline can use photons below 1'100 nm, corresponding to Egap = 1.12 eV, the photons should have a minimum energy of Egap = 1.7 eV (730 nm) for creating a pair in the amorphous silicon. Therefore, the photo current should be evaluated using a convolution integral between the incident spectrum and the spectral sensitivity. We will call "Utilization Factor" (UF) the value of this integral, which represents the fraction of the spectrum effectively useable for generating photo current.
Nevertheless, the spectral content of the solar radiation varies with the meteorological conditions and the humidity/aerosols of the atmosphere, etc. And of course PVsyst has no access to spectral measurements for a specific location or condition.
In order to estimate the Isc current at any instant, the CREST at the University of Loughborough proposes a procedure in two phases: first, characterizing the spectrum using a suited parameter, which could be evaluated from available environmental parameters, and then determine a correlation between this parameter and the spectral sensitivity of the concerned technology.
The chosen parameter is called "Average Photon Energy" (APE), and is obtained by dividing the irradiance [W/m² or eV/m²/sec] by the photon flux density [number of photons/m²/sec]. From detailed spectral measurements over one year, CREST has deduced a parametrization of this quantity according to air mass and "clear day" clearness index. Waiting for new measurements elsewhere, we can reasonably admit that this parametrization is valid at least for European climates.
The second phase is to determine a correlation between the UF, calculated for each measured spectrum for a given technology, and the APE. It is found that they are quite well correlated, and lead to a simple quadratic expression. The final amorphous spectral correction UF is shown on the figure.
It varies between about 0.5 (APE=1.45) to 0.065 (APE=1.70), i.e. a range of the order of 30%. It can be seen that the response of amorphous modules, by clear weather, decreases significantly when air mass increases (winter, morning and evening). But it remains rather good by cloudy conditions (lower Ktc).
Finally it should be noted that the final spectral correction used in PVsyst has to be re-normalized to the UF of the reference conditions when establishing the model (STC: AM 1.5 spectrum, corresponding to APE = 1.6 eV). This is the reason why the program will ask for the conditions in case of specifications based on outdoor measured data.
Four our 3-month measurement campaign, the Spectral correction calculated from this parametrization looks like the following:
where we clearly identify the clear sky conditions, and the sensitivity enhancement for cloudy conditions (but acting on low-power hours!).
NB: In the same conditions for crystalline modules, the UF varies between about 0.81 and 0.91 indicating a better use of the whole spectrum. But applying this correction to the measured data doesn't improve the results of the model.
Back to Standard "One-diode" model.
Back to Amorphous and Thin films modules.
